         Stellar Newbie
  Joined: September 12 2010 Location: Russian Federation
           | Posted: May 05 2011 at 12:54 | IP Logged
Hi,
 how quickly see the value of system variables?(TEMP1-10)
           | Posted: May 05 2011 at 13:15 | IP Logged
If you mean how can I see what the values are you can use this in a macro or trigger;
 "TEMPS " + "|" +  ph_getvar_s(2,1) + "|" + ph_getvar_s(2,2) + "|" + ph_getvar_s(2,3) + "|" + ph_getvar_s(2,4) + "|" + ph_getvar_s(2,5) + "|"  + ph_getvar_s(2,6) + "|" + ph_getvar_s(2,7) + "|" + ph_getvar_s(2,8) + "|" + ph_getvar_s(2,9) + "|" + ph_getvar_s(2,10) + "|"
         Stellar Newbie
           | Posted: May 06 2011 at 11:40 | IP Logged
not working:
 Formula Evaluation
      Execution time: 0,000 seconds.
      The formula evaluates to: TEMPS |||||||||||
           | Posted: May 06 2011 at 11:48 | IP Logged
The Formula Builder will not show TEMPS as there are no temp variable values in that environment.  Code a Macro and use the expression in a User Message.
           | Posted: May 06 2011 at 13:48 | IP Logged
The following list of variable information came from a Macro User Message that was invoked from Trigger TICONON
 temp1= TICONON temp2= 203 temp3= 0 temp4= 1 temp5=  temp6= 16 temp7= ICON SWITCH TEST temp8= 1 temp9= 17 temp10= 04.56.50
 "temp1= "  + ph_getvar_s(2,1) + " temp2= "  + ph_getvar_s(2,2) + " temp3= "  + ph_getvar_s(2,3) + " temp4= "  + ph_getvar_s(2,4) + " temp5= "  + ph_getvar_s(2,5) + " temp6= "  + ph_getvar_s(2,6) + " temp7= "  + ph_getvar_s(2,7) + " temp8= " + ph_getvar_s(2,8) + " temp9= "  + ph_getvar_s(2,9) + " temp10= " + ph_getvar_s(2,10)
