         powerondude Newbie
           | Posted: May 21 2011 at 18:30 | IP Logged
Hi all - My name is Mike and I'm new here.   I've been playing with the powerhome demo for the last couple of weeks.   My criteria was great Insteon support and great Global Cache support.  Powerhome seems to have both.
 I do have a question on IR though.   In Powerhome explorer -> Devices -> IR   I added a new IR device for my somfy shades.   I called this device BR Shade.  When I opened that device it let me add a "Key" and I was successfully able to add the "Shade UP" IR Command.   However I want to add the down and mid postion stops as well.   I can't seem to figure out how to add additional keys to this device, I tried right click, tab, the insert key, etc.  Can you really only have one key per device?  Is this a limitation of the PH demo?
 Thanks in advance for the help.
 -Mike
           | Posted: May 22 2011 at 07:13 | IP Logged
If you click on IR this should display the number of KEYs. You can then modify the number of keys for each device you have defined. There are no limitations to the trial version.
         powerondude Newbie
           | Posted: May 22 2011 at 09:50 | IP Logged
Thank You!  Don't know why I didn't see that!
