kemporama Senior Member
           | Posted: July 21 2011 at 09:42 | IP Logged
I'm helping my neighbor install some Insteon devices and PH in his house.  We got a 2413U PLM device to let PH talk to the devices.  Can someone tell me what settings on the controllers tab I should be using to get it to work properly?  It's been so long since I set my system up, plus I have an older PLC so I don't know how that will change how I need to config it new.
 We have the controller type selected as an Insteon PLM right now.  It seems like it's kind of working, we're able to auto discover devices, and I can turn them on and off from the devices tab, but when I try to set a desired level and ramprate it never converts it over to the local levels columns, and under pending operations there seems to be stuck polling requests (I forget the exact phrase it says) for each device that never disappear.  So something isn't right, but I can't figure out what.
 Thanks.
