PowerHome General
Subject Topic: Windows Vista? Post ReplyPost New Topic
CopyRon
Newbie
Newbie
Posted: November 19 2006 at 19:58 | IP Logged Quote CopyRon
Has anyone tried PH with windows Vista?
It wasn't broke 'til I fixed it!!
Back to Top View CopyRon's Profile Search for other posts by CopyRon
lllxx
Newbie
Newbie
Posted: November 20 2006 at 05:02 | IP Logged Quote lllxx
Hi,
I just installed version 1.03.4.7 on my Windows Vista (Official release) and everithing work fine excluded the driver for the USB 1132U Powerlinc controller that result as not connected.
The drivers for this device are installed and working (accoring with vista).
The device still a hidserv.dll but is larger than in XP.
No idea on how to fix that.
Back to Top View lllxx's Profile Search for other posts by lllxx
GSOUZA
Groupie
Groupie
Posted: December 06 2006 at 09:11 | IP Logged Quote GSOUZA
Not working for me in VISTA.
keep showing Script error -2 message
any help?
thanks
Gustavo
Back to Top View GSOUZA's Profile Search for other posts by GSOUZA
dhoward
Admin Group
Admin Group
Posted: December 07 2006 at 14:38 | IP Logged Quote dhoward
Gustavo,
When does this error appear? Is there any other text along with the error that might help me in tracking it down?
GSOUZA
Groupie
Groupie
Posted: December 08 2006 at 01:13 | IP Logged Quote GSOUZA
when i start powerhome, first appears this small screen saying:
"Script Server
An error occurred while creating the script server: -2"
if i hit OK, then comes this another window:
A critical error occurred at 2006-12-08 04:12:36.696.
PowerHome Version: 1.03.4.9
Error Number: 35
Error Message: Error calling external object function f_phscrver at line 18 in function f_framestartup of object w_frame.
Window: w_frame
Object: w_frame
Event: f_framestartup
Line: 18
You should make the necessary changes to correct the error and then restart PowerHome
hope it helps,
Gustavo
dhoward
Admin Group
Admin Group
Posted: December 08 2006 at 21:30 | IP Logged Quote dhoward
Gustavo,
Ok, that gets us a little further. The Script Server is the Windows Script host engine for PowerHome. Most likely the phscr.pbd activex is not properly registered or Windows Script Host is not properly configured on your machine. You may want to check the Microsoft site to make sure that WSH will run on Vista and what special procedures may need to be taken.
To ensure that the phscr.pbd is properly registered, download the following reg file here phscr.zip and merge it into your registry. You may need to edit the last couple of lines to match your PowerHome Installation directory if you installed other than the default.
See if that helps at all.
GSOUZA
Groupie
Groupie
Posted: December 08 2006 at 23:38 | IP Logged Quote GSOUZA
No Dave,
no diference after applied this reg file.
any other tips ?
microsoft is running Windows Script v 5.6 in vista.
there is an update to windows XP for Windows Script v5.6 too. maybe after upgrade to it in XP you can check whats happening.
thanks
Gustavo
GSOUZA
Groupie
Groupie
Posted: December 18 2006 at 11:14 | IP Logged Quote GSOUZA
Sorry for the wrong information.
Microsoft is Running Windows Script Host v5.7 in Vista.
not 5.6 as I mentioned above.
cya
Gustavo
dhoward
Admin Group
Admin Group
Posted: December 18 2006 at 16:31 | IP Logged Quote dhoward
If the above reg file didn't fix it then it most likely is an incompatibility between WSH 5.6 and WSH 5.7.
Looks like I'll need to setup a machine and start testing Windows Vista .
GSOUZA
Groupie
Groupie
Posted: December 19 2006 at 14:50 | IP Logged Quote GSOUZA
This would be great.
if you need any further information, please let me know.
cya
Gustavo
GSOUZA
Groupie
Groupie
Posted: December 22 2006 at 10:11 | IP Logged Quote GSOUZA
i did one more test.
i downgraded WSH from 5.7 to 5.6 and installed the Windows Script control.
nothing changes. same error.
cya
Gustavo
moniputer
Groupie
Groupie
Posted: December 26 2006 at 01:29 | IP Logged Quote moniputer
I got PH to run under "Vista Home Basic 64bit" with the 308 release of the Smarthome Device Manager. The older release of DM doesn't work.
Going to try the 32bit version(s).
More later.
Back to Top View moniputer's Profile Search for other posts by moniputer
GSOUZA
Groupie
Groupie
Posted: December 26 2006 at 22:36 | IP Logged Quote GSOUZA
another error that pops up when i tried to save the PLC settings in insteon explorer.
A critical error occurred at 2006-12-27 01:33:50.841.
Error Number: 2
Error Message: Null object reference at line 5 in clicked event of object st_saveplc of w_insteonexplorer.
Window: w_insteonexplorer
Object: st_saveplc
Event: clicked
Line: 5
Im running Windows Vista Ultimate Edition and PH with SDM 308.
Dave, this is a new error.
btw. I noted that there's no communication between PH and SDM. everything you do with PLC in PH, causes an error. if you open the SDM alone, the SDM shows that PLC is connected.
info from SDM:
downloadTimer started
timerActivate enabled
SDM:DM=active,1.01.138.308,12/27/2006 2:11:53 AM,responded,05.F9.7C,2.13,xdevices=True
starttime=00:07
cya
Gustavo
Edited by GSOUZA - December 26 2006 at 23:13
GSOUZA
Groupie
Groupie
Posted: January 21 2007 at 23:00 | IP Logged Quote GSOUZA
Hey Dave,
any news about vista?
cya
Gustavo
dhoward
Admin Group
Admin Group
Posted: January 22 2007 at 15:29 | IP Logged Quote dhoward
Gustavo,
Sorry, not yet . It probably won't be for at least another 3 weeks. Top priority at the moment is working towards a release version. Im getting beat up on it at the moment.
onhiatus
Senior Member
Senior Member
Posted: January 29 2007 at 15:44 | IP Logged Quote onhiatus
Oh oh, Dave, does this mean that powerhome will not currently run on Vista?
My current plan (wife approved - so difficult to change) involves my powerhome installation moving to a vista box in the very near future.
How much effort should I be putting into getting this plan changed? i.e. How long until PH supports Vista?
Thanks, Tony
Back to Top View onhiatus's Profile Search for other posts by onhiatus Visit onhiatus's Homepage
dhoward
Admin Group
Admin Group
Posted: January 29 2007 at 18:22 | IP Logged Quote dhoward
Not sure. Moniputer and LLLXX report it working (LLLXX with a problem with the 1132U though). However, Gustavo has a problem with the Script Server (and the SDM).
I havent had a chance to load up Vista yet, but will after the next beta comes out. Once I get it loaded up, Im hoping that whatever "adjustments" that have to be made will be relatively minor and easy to make.
That said, the more people testing it, the better. When I load it up, it will probably only be under the 32 bit Vista Business edition (since that is likely the only copy I'll have).
CopyRon
Newbie
Newbie
Posted: January 29 2007 at 19:32 | IP Logged Quote CopyRon
Vista gets released tomorrow!
johnnynine
Newbie
Newbie
Posted: February 14 2007 at 00:01 | IP Logged Quote johnnynine
Any word on Vista Compatibility?
I'd may be looking at running it on 64bit Vista.
Back to Top View johnnynine's Profile Search for other posts by johnnynine
smarty
Super User
Super User
Posted: February 14 2007 at 09:09 | IP Logged Quote smarty
Just my 2 cents......(and NOT to start a flame war)....
IMHO (if you have the choice), stay away from Vista UNTIL....the bugs get worked out (like until Service Pack 2).
As I understand it, Vista is a complete code re-write. THERE WILL BE BUGS. Do yourself a favor and spend the effort learning more about PH (using a known operating system like XP). Each day I find more and more things out about PH that make it more useful.
If you have the choice.....
Page of 4 Next >>
