seyler Newbie
Online Status: Offline Posts: 9
Posted: December 28 2001 at 20:07 | IP Logged
A very strange thing is going on when I try to use Create Timed Event. Basically, it works most of the time, but once in a while it does not. Instead of creating the event to occur at the specified time, the specified event is executed immediately. Any ideas why that might happen? I set the execution time to a global variable so that I can verify that it is valid, and in every case it fails it is valid. One thing to note is that if I execute the macro that creates the timed event once, it seems to work. It's when I execute it several times rapidly that it seems to fail - although sometimes it will fail randomly.
Has anyone else seen this?
Steve
