Posted: October 17 2001 at 19:14 | IP Logged
What does the level read? Is it blank or some number other than 100? The level indicator will be directly affected by the X-10 type you've selected. If your module is controlling a lamp, but you've set your type to an appliance module, the level will be blank. If you've set it to a module type that is dimmable and have the memory dim selected, the level will be the last known level that it had in the database. Another possibility, is that you've upgraded from 0.0.10 and have not gone through your X-10 unit codes and assigned an X-10 type.
