fasttimes Groupie
Online Status: Offline Posts: 63
Posted: October 16 2006 at 13:41 | IP Logged
I can no longer get this function to work at all. It always evaluates to !
Posted: October 16 2006 at 14:05 | IP Logged
Check the changes.txt file. I bet it changed in the last version.
fasttimes Groupie
Posted: October 16 2006 at 20:13 | IP Logged
Yup, it was deleted.
Dave, can you explain which function replaces this and how the function call works?
Edited by fasttimes - October 16 2006 at 20:33
Posted: October 17 2006 at 16:33 | IP Logged
Fasttimes,
Yep, the ph_setccobj function replaced the ph_setccbtn function. Actually, all of the ph_getccbtn??? and ph_setccbtn??? functions have been replaced with equivalent ph_getccobj??? and ph_setccobj??? functions.
All of the parameters remain the same except for the second parameter which was originally an integer named "sequence" which corresponded to the button sequence number. This parameter is now a string named "ID" and is the objects' ID instead. When your database was upgraded, all existing buttons were given default ID's.
Let me know if you have any problems,
