phil13 Groupie
Online Status: Offline Posts: 60
| Posted: April 21 2005 at 01:00 | IP Logged
Hi dave,
It will be very cool to improve the vbscript editor in powerhome (Syntaxhighlight and why not the powerhome objects management like in VBA).
In a fisrt time, why not could select an external editor like but with the possibility to keep the command panel (execute script).
As editor i use http://syn.sourceforge.net/?phpLang=en or http://www.context.cx/.
philippe
| Posted: April 21 2005 at 07:57 | IP Logged
I'll have to check that one out.
Another editor is Edit+. It also allows you to add/create your own syntax files.
Tony
| Posted: April 21 2005 at 10:14 | IP Logged
I'll look into these. The current editor was just a bare bones affair that I threw together. The intent was to allow the user to select the third party editor of his choice and I never got around to doing it .
I'll see what I can do for execute testing integration with third party editors.
phil13 Groupie
| Posted: April 21 2005 at 14:38 | IP Logged
really excellent your editor tony. Thanks
