| Posted: May 10 2007 at 20:30 | IP Logged
I'll start this thread here rather than in the bug section (since it is likely "operator error" rather than a bug).
I am using NeoSpeach's "VM Kate" and "VM Paul". I can get either of them to work in PH (when I selected the voice through the Win Xp Control Panel) , but I cannot switch them on the fly through PH functions.
I am using the function:
ph_ttssetvoice("VM Paul")
or
ph_ttssetvoice("VM Kate")
Am I doing this right? Do I have to specify a more complete path? If so, what? The voices are loacted at c:\program files\neospeach\kate16 or paul16
P.S.
ph_ttssetvoice("c:\program files\neospeech\Paul16")
doesn't seem to work either.
Thoughts??
| Posted: May 10 2007 at 20:40 | IP Logged
Better yet, if I set up my TTS engine to be SAPI5 w/ Alert (under the PH's SETUP, TTS section), how do I specify the different voice for the "alert" engine?
nadler Super User
| Posted: May 11 2007 at 07:24 | IP Logged
I do this in many of my macros and it works correctly for me.
ph_ttssetvoice("VW Paul")
Are you using it in a formula?
I installed the voices to the default directory and haven't changed it.
I've also noticed that the voices are sometimes changed as the last thing in a macro no matter what line they are placed in, in the macro. So if you play the macro a second time, the voice would change. This has to do with the immediate and post settings, I've found.
BTW I have found these voices to be amazing.
| Posted: May 11 2007 at 12:05 | IP Logged
OK....Found part of mt error. I was using "VM Kate/VM Paul". The "M" should have been a "W".
I still would like to set up the alert TTS engine with a different voice. From the help file:
Quote:
"ph_ttsctrl"
Allows control over both the normal TTS engine and Alert TTS engine.
Syntax
ph_ttsctrl ( cmd, control, data )
Argument Description
cmd Integer. The particular command you wish to issue to an engine. Use 0 to speak the data parameter asynchronously. Use 1 to speak the data parameter synchronously with no timeout. Use 2 to set the voice TTS voice to the value in the data parameter. Use 3 to pause the TTS engine. Use 4 to resume the TTS engine. Use 5 to wait until the TTS engine is done speaking with the timeout specified in the data parameter. Use 6 to get the current status of the TTS engine.
control Integer. The engine you wish to control. Use 0 for the default TTS engine. Any other value for the Alert TTS engine.
data String. Optional data to be passed depending upon the command type. Commands 0 and 2 will speak the text in the data parameter. Command 2 will set the TTS engine to the voice contained in the data parameter. Commands 3, 4, and 6 should have this value set as the empty string (""). Command 5 will convert the data parameter to a number and use that as the timeout value.
Return value
Integer. Returns a 0 on commands 0, 1, 2, 3, 4, and 5. Returns the status of the TTS engine on command 6. With command 6, a return of 0 means the TTS engine is not currently speaking. A value of 1 means that the TTS engine is currently speaking or is paused in speaking.
Usage
The Alert TTS engine allows you override the default TTS engine. If the default TTS engine is in the middle of speaking, you can issue an Alert TTS command and the default engine will be paused, the Alert TTS will be spoken and when done, will resume speaking where it left off in the default TTS engine. The default and alert TTS engines may have different voices. In order to use the Alert TTS engine, you must have your TTS engine in the Setup section of PowerHome set to "SAPI 5/w Alert". |
I believe I have SAPI 5.1 set up on my machine. I downloaded and installed SAPI 5.1 speech SDK available from here
What else might I need to do?
EDIT: I have deteremined (from using another machine with PH loaded on it) that you DO NOT need to install the SAPI 5.1 speech SDK to change voices (or to even play the voices...it does allow you to do some speech recognition however).
Edited by smarty - May 11 2007 at 20:01
jpcurcio Senior Member
| Posted: May 13 2007 at 00:25 | IP Logged
I'm not able to help here, but this does bring up a question. My SAPI included only Microsoft Sam... and it sucks. Where can I download other voices? Web searching yields very little...
Thanks...
nadler Super User
| Posted: May 13 2007 at 08:36 | IP Logged
I've had good luck with NeoSpeech voices which can be purchased here.
| Posted: May 13 2007 at 09:50 | IP Logged
Ditto...
The Neospeech Kate and Paul voices are very nice.
I plan to have Kate be the normal voice and use Paul for alerts.
