funbobbybaby69 Groupie
| Posted: August 20 2008 at 08:52 | IP Logged
Im trying to add a few more timed events. When i go to powerhome explorer / timed events i can only see 9 of my 15 insteon devices in the drop down window (device control/ inteon type) but in the ID window the device i want to control is not there.
I have tried to compare all the missing devices to the ones showing and nothing is different. Does anyone have any suggestions?
Thank you.
Rob
| Posted: August 20 2008 at 13:52 | IP Logged
I’m confused.. Where should I be seeing Insteon devices in the Timed Events? Do you mean Insteon Explorer/Devices and the drop down ID?
| Posted: August 21 2008 at 07:54 | IP Logged
no... its exactly as i wrote. Under Powerhome Explorer, timed events, I added a timer [Exact, weekdays, offset none, set the time, device control, and under ID/keys/formula - type = insteon, ID window has a drop down arrow to select your insteon device... 9 of my 15 are listed but why the other light switches aren't... is still a mystery.
| Posted: August 21 2008 at 08:01 | IP Logged
Very interesting… My 2 systems don’t show that. After Device Control the ID/Keys/Formula window does NOT have a drop down. Maybe I have a bigger problem.
| Posted: August 21 2008 at 08:42 | IP Logged
OK, I finally found the window you are referring to BUT all of my Insteon devices are showing. I’ll play with PH and see if I can drop some.
| Posted: August 21 2008 at 08:49 | IP Logged
Got it… If Device Control is checked in the Devices-Insteon- Types window they will not show. That will also affect your Device Status screen also.
| Posted: August 21 2008 at 10:00 | IP Logged
thank you for looking into that for me! :) i will play around with that. so you dont want device control for light switches and dimmers? weird. i would of thought it was the opposite.
| Posted: August 21 2008 at 10:06 | IP Logged
You rock BeachBum! That worked!!!!! THANK YOU!
