jony Newbie
| Posted: June 15 2009 at 21:20 | IP Logged
Hello.
How to set powerhome for upb controler usb pim pc interface. Why The Wizard ask for a com port and i have a usb pim.
Please advise.
thanks,
jony
| Posted: June 15 2009 at 22:10 | IP Logged
Jony,
UPB USB PIM's can be used in either serial emulation (a virtual port is created) or in USB mode. PowerHome supports the USB PIM in serial emulation mode. You can get the necessary serial emulation drivers here: (http://power-home.com/download/PLM_USB_Drivers.zip. These are
the same drivers that the USB PLM (Insteon controller uses).
Once you've installed the drivers, you should be able to see the COM port in the Device Manager (right click "My Computer", Properties, Hardware, Device Manager) under "Ports". It should show as "USB Serial Port".
You may have a problem getting the PIM to use the drivers though since you've already plugged in the PIM without having first loaded the drivers. I know one other user who was never able to get the PIM to use the drivers. You may need to identify the USB device within the Device Manager and remove it, load the drivers, and then plug the PIM in.
Once you've got a COM port assigned to the PIM, you should be able to communicate with it via PowerHome.
jony Newbie
| Posted: June 16 2009 at 11:27 | IP Logged
thanks dhoward for your reply. i click in the driver link download, download and unzip the file, hit the exe. file supossely install the file then i go to port device and is not there. please advise.
thanks.
| Posted: June 16 2009 at 12:16 | IP Logged
Did you restart Powerhome?
jony Newbie
| Posted: June 16 2009 at 12:21 | IP Logged
yes i did all that. but i don't think the drivers are at my pc
| Posted: June 16 2009 at 13:19 | IP Logged
Did you try and identify if the drivers are there in Device Mgr as Dave suggested?
jony Newbie
| Posted: June 16 2009 at 13:29 | IP Logged
is not in the divice mgr. this is what i m saying
| Posted: June 16 2009 at 13:35 | IP Logged
XP or Vista? Did you reboot?
jony Newbie
| Posted: June 16 2009 at 13:51 | IP Logged
xp, yes i did reboot
| Posted: June 16 2009 at 14:07 | IP Logged
Try and locate ftbusui.dll. Should be in the system32\drivers.
jony Newbie
| Posted: June 16 2009 at 14:15 | IP Logged
how i go to system 32 driver
| Posted: June 16 2009 at 14:25 | IP Logged
If you are in XP go to Start then Search, Files enter ftbusui.dll. See if it shows one in the Windows\ system32 anything directory.
jony Newbie
| Posted: June 16 2009 at 14:52 | IP Logged
is not there
| Posted: June 16 2009 at 15:26 | IP Logged
Sounds like the unzip didn’t go right. Unzip the folder then run CDM 2.04.06. It should start running in a DOS window. When you get through and do a search it should show in windows\system32\drvstore…..
jony Newbie
| Posted: June 16 2009 at 16:10 | IP Logged
i did that. it opens a black window config then disappear.
i guess is maybe the download link the problem
| Posted: June 16 2009 at 16:20 | IP Logged
Are you logged in as the Administrator?
jony Newbie
| Posted: June 16 2009 at 16:22 | IP Logged
yes
| Posted: June 16 2009 at 18:12 | IP Logged
When I did it I had to extract twice. Once for PLM_USB_DRIVERS.ZIP and then from that ran the CDM*** and selected EXTRACT ALL. After that I did the execute of the CDM***
jony Newbie
| Posted: June 16 2009 at 18:40 | IP Logged
i did all that. when press to exe cdm it open like run (black window)quickly i read installing driver then disappear
