| Posted: July 21 2010 at 20:31 | IP Logged
I just got my new Brultech ECM-1240 powermeter connected to my service panel. I can now see individual circuit loads (like Spa, AC1, AC2, oven etc)
I am hoping to find ways to have PH "respond" to the varying wattage levels as electrical loads vary.
For example, I would love to be able to have PowerHome totalize the AC runtime each day. By knowing the outside temp and humidity, I could calculate AC effectivness and judge this over time (know if your compressor is starting to get low on refrigerant etc).
Anyway, the ECM-1240 stores its data is a SQL database composed of only 4 tables (the structure looks very understandable when viewed with a DB viewer- I use SQLite Database Viewer).
My question is this: Is there anyway to use PH's multi-editor to pull information from the ECM-1240 database? If so, I would love to see an example SQL macro/command sequence.
If PH can do this, I am planning to use the "file change" plug-in to sense when the database has been updated and then to trigger whatever SQL based "macro" is needed to pull out the information I specify. My only problem is that I DON'T KNOW SQL.
Anyone have any thoughts on this topic?
| Posted: July 22 2010 at 16:41 | IP Logged
....NEW APPROACH....
The ECM-1240 does have a option to "Forward Data" via TCP/IP and a PORT number. See the picture below.
When I use a port sniffer to see what the Brultech ECM-1240 is sending out, I can see the following information:
I can see all the data being sent out every 3 seconds (3 seconds is configurable). Cool!!!!
Now, is there a way to maybe use the UDP plugin to trigger when new data is sent out? and then get the data into PH.
I have not been able to set up the UDP Listener plugin. Does anyone know how to set it up? I am not sure how to set up the configuration file for the plugin.
Comments???/Help???
| Posted: July 23 2010 at 12:52 | IP Logged
Smarty,
Taking a look at the screenshots, I would think you would get the best results by using the PH Socket plugin. I don't see anything in the screenshots that the Brultech is actually sending UDP broadcasts and it appears to be more of a point to point TCP connection.
As such, it should be very simple to setup and give it a try. From the help file, here is the documentation on the PH Socket plugin:
Raw Socket
Launch Data (ActiveX Classname): PH_Socket.phsocket
Initialization Data: The IP address to connect to, a space, the port to connect to. Can also be left blank to connect manually after launch
This plugin provides raw socket connectivity for PowerHome. If an IP and port is supplied in the Init Data, then a connection will be established when the plugin is loaded. Otherwise, you can initiate a connection manually using the ph_picmd function. This plugin supports several commands via the ph_picmd function. Command 1 will cause the plugin to send the data in the data3 parameter over the socket if a connection is established. Command 2 will establish a connection manually to the IP in the data3 parameter and the port in the data1 parameter (you must not be currently connected). Command 3 will disconnect the socket if it's currently connected. Command 4 will return the status of the current connection (0 = connected, 1 = not connected). Command 5 returns the current remote IP of the socket. Command 6 returns the remote port of the socket.
The plugin will also fire generic plugin triggers. The trigger for command 1, option 1 will be fired when data is received on the socket. The trigger for command 1, option 2 will be fired when the socket establishes a connection. The trigger for command 1, option 3 will be fired when the socket disconnects.
You won't be sending any TCP data via the ph_picmd function and will instead just create a generic plugin trigger for command 1, option 1. Use one of the macros or formulas that displays all of the Local and Temp variables to determine which one contains the data you're interested in.
Im very interested in hearing how all this works out so please post your results.
| Posted: July 23 2010 at 16:56 | IP Logged
Great to hear that things are working out, and great to have you back!
Yes, the Raw Socket plugin did the trick.
A trigger off this plugin with command 1, option 1, triggers each time the ECM-1240 sends out data.
The [TEMP] variables contain all the passed information.
For others to reference, I use a formula button for viewing all the [TEMP] variables when the trigger fires:
ph_usermessage("temp1= " + ph_getvar_s(2,1) + " temp2= " + ph_getvar_s(2,2) + " temp3= " + ph_getvar_s(2,3) + " temp4= " + ph_getvar_s(2,4) + " temp5= " + ph_getvar_s(2,5) + " temp6= " + ph_getvar_s(2,6) + " temp7= " + ph_getvar_s(2,7) + " temp8= " + ph_getvar_s(2,8) + " temp9= " + ph_getvar_s(2,9) + " temp10= " + ph_getvar_s(2,10))
From this formula, you will end up with:
temp1= 2 temp2= 0 temp3= 259 temp4= 7080 temp5= CH1PAa=1082&CH2PAa=2&CH1PPa=1082&CH2PPa=1&CH1Aa=9.2&CH2Aa=0. 3&Paux1a=6&Paux2a=1001&Paux3a=0&Paux4a=0&Paux5a=0&KWhCH1a=34 1.05&KWhCH2a=0.693&KWhAux1a=25.432&KWhAux2a=81.587&KWhAux3a= 0.358&KWhAux4a=90.042&KWhAux5a=0.035&Timea=08:18:38&Volta=25 0.2&DevSNa=205744 temp6= 27 temp7= RAWSOCKET temp8= 1 temp9= 1 temp10= 192.168.0.106
You can see that "temp5" is where all the data of interest resides.
I then use ph_regexdiff to extract out the data from [TEMP5].
WaHoo!!! PowerHome can now understand and act off my home power consumption. GOOD STUFF!!!
Edited by smarty - July 23 2010 at 17:03
| Posted: July 23 2010 at 21:39 | IP Logged
Smarty,
Awesome! Glad the Socket plugin did the trick. I was going to suggest using one of the regex functions to extract the data but see you're way ahead of me.
Ive been interested in monitoring my power consumption for a loonnng time (primarily concerned with instantaneous kwh being drawn from the entire house) so was very interested when I saw your post. Im not even sure what kind of hardware will do what I want but will do some research on the Brultech to see if it will fill the bill for me.
| Posted: July 24 2010 at 09:52 | IP Logged
The ECM-1240 can monitors 7 channels/circuits, 2 of which could be net (production minus consumption) power. Units can be "stacked" such that additional circuits can be measured (7/unit). It measures true, load factor power.
Presently, it seems a fair number of "cocooners" think that this meter is one of the better ones available, (price is fairly reasonable as well).
Here is their link:
Webpage
Steve
PCarp Newbie
| Posted: June 21 2011 at 23:41 | IP Logged
How is the ph_regexdiff statement formatted to extract the
information in temp5= ?
Paul
Edited by PCarp - June 22 2011 at 23:06
| Posted: June 23 2011 at 09:51 | IP Logged
See the zipped macro that I exported. Hope this helps.2011-06-23_095326_ECM-1240.zip
Edited by smarty - June 23 2011 at 09:53
PCarp Newbie
| Posted: June 23 2011 at 10:42 | IP Logged
Smarty,
Thanks for the information, after looking at the macro I can see why I was having problems.
I will be able to try it out this evening.
Paul
PCarp Newbie
| Posted: June 25 2011 at 20:18 | IP Logged
Smarty,
The macro cleared up my problems. I am able now to import the ECM-1240 data into PowerHome.
I am waiting on a couple more ECM-1240 devices to finish up the project. Apparently Canada has a postal strike going on currently so I am not sure when I will be able to complete it.
Paul
