PowerHome Programming
Subject Topic: Web Server Help Post ReplyPost New Topic
smarty
Super User
Super User
Posted: January 13 2011 at 11:53 | IP Logged Quote smarty
I am trying to figure out how to use PH's built in web server to as a replacement for the web server (Cassini web server) that installs itself as part of the Brultech ECM-1240 power meter.
From the the Brultech forum, I am told that I should be able to just copy over the Brultech Webserver directory and place in within the c:\powerhome\web\ directory location.
Discussion link
I have done this, but how do I "point to" these files so that the PowerHome web server "serves them up".
When using Internet Explorer to view the Brultech page, the web address is "http://localhost:9009/#"
The powerhome "main" web address is "http://localhost:90/ph-cgi/main?"
Any ideas how to view the Brultech pages from within Powerhomes web server?
Edited by smarty - January 13 2011 at 12:00
smarty
Super User
Super User
Posted: January 13 2011 at 16:45 | IP Logged Quote smarty
duplicate...sorry
Edited by smarty - January 13 2011 at 16:46
dhoward
Admin Group
Admin Group
Posted: January 15 2011 at 13:02 | IP Logged Quote dhoward
Smarty,
I tried to follow the link to the Brultech site but it requires registration .
If the files are just standard HTML files, then PH should have no problem serving them up. If they're script based files (ASP, PHP, etc), then the PH webserver does not support this. If you were to post a sample file, I could give you a better idea.
Anyways, if you've copied the Brultech directory to a subdirectory beneath the PH web directory (Im going to assume a subdir name of "brultech" below with a main launch page of "start.htm") then all you need to do to access it is:
http://localhost:90/brultech/start.htm.
If this works for you, you can add it to the PH main webpage menu by going to PowerHome Explorer Setup|Web and adding it to the "Menu" section.
Edited by dhoward - January 15 2011 at 13:05
