           | Posted: January 04 2014 at 10:51 | IP Logged
Just got several of the new SmartHome 2342-222 and 2342-
 232 RemoteLinc Keypads to replace my old 2440's that ate
 batteries like a hungry dog!
 The PH "Auto Discover" device in the PH Insteon Explorer
 "Devices" tab doesn't seem to work for these guys.  It
 discovers a type "75" that is devoid of parameter data,
 and which PH thinks is capable of only a single
 responder.  Any attempt to create Links from this remote
 to other devices results in error comments if you try to
 use anything other than button 0 as the controller
 button.
 Does anyone (Dave) know the parameters to manually define
 a new "Type" for these units?
           | Posted: January 05 2014 at 06:14 | IP Logged
Two new 'Types' are required.  Pattern after the 2440
 Type
 Types
 Ctlr Groups
 2342-222 = 8
 2342-232 = 4
 Resp Groups - both = 0
 DevCat = whatever the new RL2/Mini Remote presents
 SubCat = whatever the new RL2/Mini Remote presents
 MemTop = 4096
 DB Type = Linear
 Under 'Devices' the new RL2/Mini Remote will have
 IEngine = I2CS
 Use Ext for ALDB = checked
 Note that the Group numbers are odd compared to other
 multiple button devices.  Normally a KPL, old RemoteLinc
 have
 button 1 = Group 1
 button 2 = Group 2
 button 3 = Group 3
 etc
 For the new RL2/Mini Remote the button Group numbers are
 assigned as follows for the 8 button
 button B = Group 1
 button A = Group 2
 button D = Group 3
 button C = Group 4
 etc
 The 4 button Groups are A-D Groups 1-4
  Edited by grif091 - January 05 2014 at 06:17
           | Posted: January 05 2014 at 07:12 | IP Logged
Lee-
 Thanks!  It is always a pleasure to have your knowledge base available to answer these device particulars.
 To add to your info I submit the following, where
 8-scene is model 222 and 4-scene is 232 ...
         222  232
 DevCat   0    0
 SubCat  18   16
 Here is an image of the button to Group assignments for the 8-scene remote (which as you point out are reversed from the normal RemoteLinc history)    ...
  Edited by GadgetGuy - January 05 2014 at 07:13
