Online Status: Offline Posts: 933
Posted: December 28 2024 at 12:26 | IP Logged
I bought a used Switchlinc and when it arrived I discovered the Device
ID was painted over (sigh). Before I hassle the seller, is there a way
to use Powerhome to get the device ID? Thanks!
Posted: December 28 2024 at 14:32 | IP Logged
So the original PH Quickstart says that you can use Auto Discovery
and all the details are in the PH manual, except they aren't. the PH2
Quickstart says to use the Add Insteon Wizard for Auto Discovery but I
don't have that Wizard (maybe because I'm one rev. behind because
of comm bugs in the latest release). Anyway - I was able to do it via
Manual Linking. I never doubted for a moment that PH would have
some way to do it, just took some time to find it....
Edited by jeffw_00 - December 28 2024 at 14:33
Posted: December 29 2024 at 11:05 | IP Logged
Glad it worked and you found a solution..
