Handman Senior Member
           | Posted: February 18 2009 at 00:29 | IP Logged
Powerhome is no longer communicating with any of my Insteon devices.  All the devices have been reddened out on the Device tab after allowing polling.  I first suspected a problem with the PLC (Smarthome 2814U), however the LED blinks normally when a signal is sent out and when switches are turned on or X10 signals are received.  The raw event log also records these incoming and outgoing signals.
 E.g.,
 PLC:eventraw=03
 PLC:eventraw=04
 PLC:eventraw=03
 PLC:eventraw=03
 Event 01 and 03 seem to correlate with incoming Insteon commands and 08 with incoming X10 signals.  Also, the PLC will transmit Insteon and X10 commands, but not receive any acknowledgment that the signal was received (although lights do turn on).  The event log records outgoing signals, but will not "see" or record any incoming signals.  I double-checked to verify that the right boxes are checked in the event log setup.  I have also (apparently successfully) reloaded the timer core app and reloaded all the devices into the PLC.  Since the PLC seems to see something, why isn't PH communicating?  Help!
  Edited by Handman - February 18 2009 at 00:31
