        | bobw Newbie
          PH has been working for several months but now it can't connect to the PLC.  isresponding is working threw the device manager.  If I look into the "about box" of PH it tells me NOT connected  ID INsteon device manager controller
           | Posted: January 12 2010 at 22:17 | IP Logged |   |
 Edited by bobw - January 12 2010 at 23:17
        | grif091 Super User
          Double click on the blue T shaped Icon in the system tray and compare to the following PLC connect activity.
           | Posted: January 13 2010 at 06:08 | IP Logged |   |
 ui:getplcstatus
 PLC:getPLCstatus=beginlist
 port=USB4
 connected=True
 firmware=2.13
 id=11.F3.CB
 devicetype=InsteonPLC-USB
 lastErrorMsg=#0:
 endlist
 uifinished:getplcstatus
 ui:getlinks
 uifinished:getlinks
 ProgressStart
 ProgressMax=1024
 Progress=0%,0,1024
 Progress=12%,128,1024
 downloadTimer started
 timerActivate enabled
 Progress=25%,256,1024
 Progress=37%,384,1024
 Progress=50%,512,1024
 UI:ConnectedAndReady
 Progress=62%,640,1024
 SDM:DM=active,1.01.138.308,1/13/2010 6:03:54 AM,responded,11.F3.CB,2.13,xdevices=True
 starttime=00:08
 Progress=75%,768,1024
 Progress=87%,896,1024
 ProgressEnd=True
 ProgressStart
 ProgressMax=1024
 Progress=0%,0,1024
 ProgressEnd=True
 Lee G
        | bobw Newbie
          I typed in the cmds
           | Posted: January 13 2010 at 17:39 | IP Logged |   |
 ui:getplcstatus
 port=USB4
 connected=True
 firmware=2.13
 id=0E.D7.FD
 lastErrorMsg=#0:
 endlist
 ui:getlinks
 ProgressStart
 ProgressMax=1024
 Progress=0%,0,1024
 ProgressEnd=True
 PLC:getlinks=beginlist
 endlist
 uifinished:getlinks
 ui:ConnectedAndReady
 PLC:ConnectedAndReady=ERROR:unknown command
 uifinished:ConnectedAndReady
        | BeachBum Super User
          I wonder where this is coming from? ui:ConnectedAndReady Do you have anything triggering at startup?
           | Posted: January 13 2010 at 17:45 | IP Logged |   |
 Pete - X10 Oldie
        | bobw Newbie
          I typed it in.  tried to follow the post above
           | Posted: January 13 2010 at 18:27 | IP Logged |   |
        | bobw Newbie
          it looks to me like SHDM is talking to the PLC but PH can't find smart home device manager
           | Posted: January 13 2010 at 18:29 | IP Logged |   |
        | grif091 Super User
          You do not see the blue T shaped Icon in the system tray when you start Powerhome?
           | Posted: January 13 2010 at 20:06 | IP Logged |   |
 Lee G
        | bobw Newbie
          yes and by clicking on it I can put it into DM mode, all commands work from there but PH is still trying to connect to the controller.
           | Posted: January 13 2010 at 21:02 | IP Logged |   |
        | grif091 Super User
          If the blue T shaped Icon appears in the system tray PH is loading SDM3.  What level SDM3, 308 or 235 are you running.  If not 308, execute the 308.bat file in the Device Manager subdirectory in the Powerhome program files.  Did you recently get a USB driver update from Microsoft.
           | Posted: January 13 2010 at 21:31 | IP Logged |   |
 Lee G
        | bobw Newbie
          I've run the 308 batch still no change
           | Posted: January 14 2010 at 19:00 | IP Logged |   |
        | dhoward Admin Group
          Bob,
           | Posted: January 14 2010 at 20:01 | IP Logged |   |
 Any recent changes in your system or did this just start out of the blue?  Also, what OS are you running?  If you say Vista, then I might know whats going on.
 Let me know and we'll proceed from there.
        | Back to Top |       |
        | bobw Newbie
          Vista Home
           | Posted: January 14 2010 at 20:12 | IP Logged |   |
 No changes except it is setup to auto update
        | dhoward Admin Group
          Bob,
           | Posted: January 14 2010 at 21:23 | IP Logged |   |
 Did you install PowerHome in the default install directory (c:\program files\powerhome) or did you install into the Vista recommended directory (c:\powerhome)?
 Im suspecting that you're in the c:\program files\powerhome and that auto-update may have affected settings concerning UAC.  If you are installed into c:\program files\powerhome, I would copy your pwrhome.db and pwrhome.ini files to a safe location (these two at the minimum...if you're using plugins or have custom webpages, etc. then you'll want to copy those files as well).  Check the date/time of the pwrhome.db and pwrhome.ini files to make sure that have the date/time you shut PowerHome down so you know you have the right ones.  Next uninstall PowerHome and manually delete the PowerHome directorys.  Follow these Vista instructions:
 Install in c:\powerhome as an administrator
 Copy over any files you had previously saved
 pwrhome.exe should not be in XP compatibility mode and should not be run as administrator. UAC can be enabled.
 sdm3.exe should have properties set for ALL USERS to run in XP compatibility mode.
 May have to manually launch PowerHome as administrator a couple of times before its able to successfully launch sdm3.exe without errors.
 Give that a try and lets see where we get.
        | Back to Top |       |
