| Posted: March 03 2004 at 21:30 | IP Logged
Todd,
Did you use the formula exactly as it was in the sample?  If so, it won't work as I had it temporarily disabled since it was getting on my better half's nerves.
The very first line of the macro is "Jump 999" which will essentially cause the macro to jump to line 999 which is waaaayyy after the end of the macro so it just does nothing.  If its still there, just delete the first line  .
If thats not the problem, let me know and we'll work it out.  Another way to test and verify is to change the last line from TTS to Message Box with TTS.  That way you can see exactly what it's trying to speak.
