         williammanda Groupie
           | Posted: August 19 2011 at 21:43 | IP Logged
I'm looking for some insight on how to resolve this issue. I currently use Mythtv which is linux and am interested in your Windows product PowerHome. I'm trying to figure out how to use both off of one remote. It seems there are some possibilities ie telnet, web browser, etc... The ideal situation is to have the remote to be able to control both software packages off of two different computers. I have read in the posts that the Nokia tablet ie 700 or 800 series is being used here. This is one possibility where I could see this happening depending on how the switch was made between windows and linux. Please give me your insight on possible solutions.
           | Posted: August 25 2011 at 19:21 | IP Logged
William,
 Ive read your post a couple of times and still not quite
 sure what you'd like to achieve.
 Im aware of MythTV as a Linux based DVR type software and
 PowerHome is obviously Windows based.  From what I
 gather, you're looking for a method to remotely control
 both PowerHome and MythTV from a single "remote" pc or
 controller of some sort.  Im not sure what control
 options are available for MythTV so not sure how this
 part would work but PowerHome has a number of methods of
 remote control including the webserver (which should work
 fine on Windows, Linux, or handheld clients), the Remote
 clients (which are Windows based software), the socket
 server if someone would like to roll their own and
 Windows messaging for control via another program on the
 same machine.
 In my setup, I use SageTV on a dedicated machine and
 remotely control it from PowerHome via the DCC
 (Distributed Control Client).  The DCC runs on the SageTV
 server and sends keystrokes to the SageTV program.
 PowerHome communicates with the DCC using the Socket
 server.  Granted, since MythTV is Linux, you cant run the
 DCC as its Windows based but something similar may be
 able to be created for Linux.
 Not sure if the above was helpful or not but all I can
 think of at the moment.
           | Posted: August 25 2011 at 19:48 | IP Logged
I tried looking up Distributed Control Client or DCC on the internet but got no where. I was looking at this for some kind of bridge to accomplish what I wanted:
 http://irreco.garage.maemo.org/documentation.html
 Mythtv can be controlled several ways: LIRC, telnet, commandline, etc...
 Please let me know your thoughts.
           | Posted: August 25 2011 at 21:01 | IP Logged
William,
 The DCC is a PowerHome program and can be found on the
 PowerHome download page (http://www.power-
 home.com/download.aspx).
 If MythTV can be controlled via Telnet, this may be one
 of your best options.  PowerHome has the generic socket
 plugin which could easily do Telnet.  You also have
 available the internal functions ph_sendsocketdata and
 ph_sendsocketdata1.  This would probably be the first
 method I would explore.
           | Posted: August 25 2011 at 21:24 | IP Logged
Would you explain how "internal functions h_sendsocketdata and ph_sendsocketdata1" work? And how I could use them in my example.
  Edited by williammanda - August 26 2011 at 00:25
