MrGibbage Super User
| Posted: August 17 2015 at 05:43 | IP Logged
Does anyone know of a dead bolt and/or door knob solution that can easily be
integrated with PH? Something with wifi perhaps. Specifically, I want to be able to
unlock my front door from PH. If it has a web server or even a generic network socket
server, I can make it work. I don't want something that is cloud based or requires you
to use a specific app on a phone, but rather something more "open".
Skip
__________________ Skip
| Posted: August 17 2015 at 07:28 | IP Logged
Someone may know of one, but in case not, here is a DIY solution...
https://www.sparkfun.com/products/13648?_ga=1.56589923.95780 2423.1382616198
| Posted: August 17 2015 at 09:27 | IP Logged
This is what I use:
Controller
along with:
Deadbolt
Edited by dhoward - August 17 2015 at 09:29
nick7920 Senior Member
| Posted: August 17 2015 at 12:51 | IP Logged
I just received z-wave stuff on Friday and testing not
with PH yet.
Hoping Dave will support soon and mean while I can
come up with my solution to use it.
I went with Z-wave homeseer A2Z-link controller and
Yale YRD240-ZW-0BP
adding Z-wave alone is expensive - my reason I see so
much stuff out there for Z-wave it will be hard for
Insteon to keep it up.
with this Z-wave controller adding lock and using it
from there app it easy.
so far I can control the lock thru web app, sending
Json commands and with telnet were port remains open
and you get update right away, I don't have socket
client of my own yet.
p.s. I also wanted Not cloud base but rather control
it myself.
Nick
Edited by nick7920 - August 17 2015 at 12:55
| Posted: August 18 2015 at 15:22 | IP Logged
I use the PH plug-in for generic socket and was able to
to control the lock (also another Z-wave device) from PH
and got the trigger working. I will create another post
once I complete the testing.
| Posted: February 17 2018 at 19:13 | IP Logged
Resurrecting a nearly-three-year-old thread. Has the
field changed any? Anyone using smart house door locks?
| Posted: February 18 2018 at 18:23 | IP Logged
Skip,
I was still using the Insteon morning link deadbolts but they just don't seem to hold up. I will probably migrate over to either a zwave (once I
finish the support) or wifi enabled solution.
| Posted: February 23 2018 at 13:21 | IP Logged
Skip
I am using Z-wave door lock since my last post , more
like over 2 years ago.
created my own basic plugin for homeseer z-wave
controller and PH.
its been working fine and now I have few z-wave
devices working PH also.
Nick
Farnham Newbie
| Posted: July 14 2018 at 06:03 | IP Logged
Can you share this plugin of yours with the community,
Nick? It sounds like just what I need.
Edited by Farnham - February 24 2023 at 08:18
| Posted: July 14 2018 at 12:17 | IP Logged
Farnham,
Do you have homeseer Troller controller ?
Nick
