tbeckman Senior Member
Posted: October 06 2008 at 17:26 | IP Logged
I am had a few timed events already created before I upgrade last month to v2. Haven't done anything in timed events since, then today I was trying to change a timed event when it gave me an error. Now I can't seem to chose the macro to run without getting this error.
A critical error occurred at 2008-10-06 14:11:33.046.
PowerHome Version: 2.0.0
Error Number: 6
Error Message: Invalid DataWindow row/column specified at line 137 in itemchanged event of object dw_detail of w_explorer.
Window: w_explorer
Object: dw_detail
Event: itemchanged
Line: 137
Posted: October 08 2008 at 10:56 | IP Logged
Help can't seem to create new timed events now. Thank you.
Posted: October 08 2008 at 12:10 | IP Logged
It's happening again with a Macro this time. I built a new macro yesterday and everything worked fine with... today I was looking at it and tried to click on another macro when I got a message stating that something in that macro was missing (field not filled in or using a character that is no supported). I have seen these messages before, but it was truely a blank field or a character I shouldn't have used. However, now it displays it when there isn't a problem and the only way to get out of it is to allow it to delete my macro. I have lost several timed events and now a macro just because I looked at them and couldn't get out. I am afraid to open any more for fear I will loose them and have to build. Has anyone else had this issue? Thanks.
nadler Super User
Posted: October 08 2008 at 13:43 | IP Logged
My macros are working fine in PH2. I can create, edit
and delete them with no problem.
I think Dave is aware of the Timed Event issue and is
working to put out a new beta fixing it. He changed
Timed Events substantially in PH2 to add a couple of
fields including the ID field. I think the ID field is
broken.
If you have a simple Timed Event that you want to add,
you can go to the Timed Event Wizard in PH2 and add it
there. That seems to work well.
I'm sure this issue will be corrected shortly.
Posted: October 08 2008 at 13:59 | IP Logged
I reinitilized PH after experiencing the macro disappearing and it came back... so maybe my problem is only with the timed events... thank you for letting me know about the wizard... I will try that.
Posted: October 16 2008 at 11:05 | IP Logged
Any idea when timed events will be fixed... I can no longer create a timed event without error and if I touch my currently created timed events they error out and then I loose them. I am really missing some of the timed events since upgrading. Thank you.
Posted: October 16 2008 at 13:26 | IP Logged
I think adding/modifying timed events from the web page works, too. It's not a fix but a work-around to use until the problem is identified and addressed.
Posted: October 16 2008 at 13:53 | IP Logged
Wow... I didn't even know I could add from the web page... great... thank you for letting me know.
