ph0n33z Newbie
Posted: October 01 2007 at 18:23 | IP Logged
Greetings everyone. I have been looking at using powerhome in conjunction with my ELK M1. However, one of the main features I want to be able to add to my ELK is Cheaper RFID support.
For those of you who are not aware, this is currently supported by CQC and HS. They are active RFID devices which are EXTREMELY inexpensive and have had great feedback from the community. If powerhome could implement this, it would open up some great HA functionality which has been limited to X10.
Here is a link to the devices:
http://stores.ebay.com/Ananiah-Electronics_Active-RFID_W0QQc olZ4QQdirZ1QQfsubZ6029549QQftidZ2QQtZkm
http://www.wingsnwakes.com
Here is a link to the homeseer and cqc plugin threads:
http://board.homeseer.com/showthread.php?t=117792
http://www.charmedquark.com/vb_forum/showthread.php?t=4041&h ighlight=rfid
I hope to hear back from you guys!
Posted: October 01 2007 at 19:29 | IP Logged
It looks like the receiver just transmits the device ID (a 4-character code) via RS232, so it would be inherently supported via PH's comm functions. Also, someone could write a plugin for it.
Posted: October 03 2007 at 15:03 | IP Logged
ph0n33z,
I looked at the links and it's definately doable. The protocol looked simple enough, but unfortunately, I don't currently have any of these devices to test with.
If you have these devices and could post a hyperterminal output that shows the format of the received codes, then it would be rather trivial for me to create a plugin for it for PowerHome.
cmhardwick Senior Member
Posted: October 04 2007 at 09:48 | IP Logged
Love how he says "trivial to create a plugin"
Posted: October 04 2007 at 14:28 | IP Logged
As I understand it, the data is just a 4-character code followed by a space ("r2D2 ")
sailwhatcom Newbie
Posted: January 23 2009 at 18:48 | IP Logged
Hello Everyone,
Curtis has closed his store Wings-n-Wakes store and you
can purchase this hardware at:
http://cliste.sailwhatcom.com
... and let me know if you need any help with a plug-in.
Cheers,
Jeff
yalk Newbie
Posted: January 24 2011 at 23:40 | IP Logged
It is news for me that ELK is cheaper than RFID support. I had always thought that it was the other way around. Anyway I checked out the RFID devices available in eBay. I am of the view that they are extremely cheap. I have decided to purchase the dual receiver module. I think I will be able to get it for less than $55.
__________________ hello
