fasttimes Groupie
Online Status: Offline Posts: 63
Posted: May 01 2006 at 21:42 | IP Logged
I would like to see on/off devices listed on the "device status" page (both on PH and the PH web page).
Is it possible to just remove the dim box for these? The lack of being able to control my fans while I can control all the lights is frustrating.
-Mike
Posted: May 01 2006 at 23:33 | IP Logged
Mike,
Im not sure exactly what you're asking. The device status screen (both web and PH client) should show ALL X10, Insteon, Digital I/O, and Analog I/O devices whether they are status only, dimmable, or on/off.
If you're getting something different, then let me know. You may have a filter turned on or if you're speaking in about Insteon devices, they may have a device type that is flagged as "Control" which keeps them from showing. An Insteon "Control" type is primarily designed to identify a switch used in a 3 way circuit that does not have the "load" connected or a ControLinc. Changing the device type to one not flagged as "Control" will enable the device to be shown on the Device status screen.
Let me know if it's something else.
fasttimes Groupie
Posted: May 02 2006 at 16:21 | IP Logged
It worked, thanks!
