guerrand Senior Member
Online Status: Offline Posts: 106
| Posted: January 26 2007 at 09:56 | IP Logged
I rigged up a door sensor using a wireless motion detector. It's working pretty well except I am trying to get it to flash a light continuously if the door its on is left open more than ten minutes. Everything works except for the flashing cycle for the light.
JUMP if( ph_getx10stat("DOOR") = 1,999, - 3 )
the -3 would send it back to the start of the loop. The light should keep flashing until the door is closed properly.
When I test it it goes through the first run of the cycle ok but when it gets to the jump line it seems to just stop.
I tried to make sure my syntax is all correct (and made sure the - had breathing room)
What did I do wrong? (cuz I know I always do something wrong!)
Also, how can I get the ph status page to update when I use a palm pad or other rf device to turn lights on or off. (I tried doing an echo but that just caused chaos)
Edited by guerrand - January 26 2007 at 10:29
__________________ VuMe
| Posted: January 26 2007 at 13:33 | IP Logged
Assuming the start of the loop is three lines before that one, it should be fine.
xxx
xxx
xxx
xxx
xxx
Status Page Update: ph_devicerefreshstat( )
| Posted: January 26 2007 at 14:08 | IP Logged
well, for reasons unknown it won't jump. I can't explain why. lol
Just for kicks here's the full lineup for the macro.
x10 light off
delay 3000
x10 light on
(this line is as formula, immediate) JUMP if( ph_getx10stat("FREEZERDOOR") = 1,999, - 3 )
I should have described the second issue a little better.
I want ph to recognize when I turn a light on or off externally of the program itself. when I use a palm pad remote to adjust a light I see the the mr26a is receiving the rf signal but ph doesn't update the status of the light to match the current condition.
The command given just refreshes the listing. It doesn't enter external rf commands into the system.
| Posted: January 26 2007 at 17:39 | IP Logged
Guerrand,
1st suggestion...change the Delay 3000 to a Wait 3. This won't fix the problem, but makes PowerHome more efficient. During a Delay, PowerHome is unable to process any other commands...a Wait doesnt have this limitation. Delays are good for very small waiting. If you've got to wait longer than a second, then a Wait command is better.
If I read your message correct though, your last macro line is a "Formula" command of type Immediate and you've typed "JUMP if( ph_getx10stat("FREEZERDOOR") = 1,999, - 3 )" in the Send Keys field. If so, this is the problem. Change the macro line command from "Formula" to "Jump" and take JUMP out of the formula (send keys) column so that just the IF statement is left.
| Posted: January 26 2007 at 18:12 | IP Logged
That took care of it. Works perfectly now. :D
Once again I have to say, great job on this. I tried out homeseer for a couple days but came right back the the PH!
Any ideas on the second problem? Is it even possible for ph to recognize and log an action done with a rf remote and not done via ph?
| Posted: January 26 2007 at 23:37 | IP Logged
Guerrand,
Glad to hear it's working now.
Concerning the second problem...should be an easy fix. PowerHome has an option to update the X10 status on received RF from the MR26A. Just open the PowerHome Explorer and navigate to Setup|Controllers and click on the Settings button for the MR26A. Make sure that the "Update X-10 Status" box is checked. If it wasnt checked and you checked it, you need to either restart or reinitialize in order for the changes to take effect.
You can also take care of the updates manually if you prefer (hence the checkbox). Just create a trigger on "Incoming X10 RF" on the X10 devices whose status you want to monitor or update and the trigger will fire anytime you send the command from the palm pad.
| Posted: January 27 2007 at 01:13 | IP Logged
For some reason things don't like to work the way they're supposed to. The "Update X-10 Status" box has always been checked. Its never updated based on commands received tho. Guess I'm gonna be making some triggers. lol
| Posted: January 28 2007 at 11:07 | IP Logged
Well, it's working mostly once I made the 18 triggers. lol I doesn't recognize dim/bright actions but I could make another 12 to handle that.
If anyone has any ideas why the "Udate X-10 Status" option might be acting up please pipe in! I'd be much happier if I could fix whatever is wrong so I can trim my triggers back down.
In leu of that, folders in the triggers area would be nice to organize all these. :D
| Posted: January 30 2007 at 20:58 | IP Logged
Anyone?
| Posted: January 30 2007 at 22:53 | IP Logged
I don't have an MR26A so I can't help that much. Give Dave a couple more days.
| Posted: January 30 2007 at 23:05 | IP Logged
I hope we can find out why it might not be working correctly. I'm building quite the list of triggers. lol
It might end up being a moot point though. I have 2414U coming in tomorrow. Gonna start converting over to Insteon. (which will prolly mean a bunch of new problems to figure out. lol)
| Posted: January 30 2007 at 23:30 | IP Logged
I had the same thing happen before. I created a ton of triggers before I found out that the W800 could be set to echo out to the power line.
| Posted: January 31 2007 at 00:11 | IP Logged
Well, atm I don't have a direct powerline interface for ph. Just rf to individual x10 receivers. And I tried doing echo on it, it kinda works, the actions are recognized.... but it freaks out by repeating all rf commands over and over... I end up having to shut down ph to stop the madness. lol
| Posted: January 31 2007 at 12:40 | IP Logged
*daces*
The 2414U echoed did the trick! Now I can clean up my triggers!
