| Posted: September 23 2008 at 21:01 | IP Logged
To TonyNo or anyone else......
Maybe this is easy, but it is not coming to me....how do I get the CID plugin to play the SIT tone?
I have the SIT tone file (one tones you hear when the telephone line has been disconnected) and don't mind sharing it. I am just not sure how to incorporate it into the CID plugin for when a predefined telemarketer calls.
Ideas?
| Posted: September 24 2008 at 06:55 | IP Logged
I cheated!
I recorded it at the beginning of my OGM on my answering machine.
In a related matter, I just ordered a new gizmo that I will integrate with PH that will not only hang up on telemarketers, but will play a message requesting that the number be removed from their call list.
The Phone Butler
mustangcoupe Super User
Online Status: Offline Posts: 308
| Posted: September 24 2008 at 18:00 | IP Logged
let me know how that works for you tony. I was thinking of it when I saw it over on CT
__________________ Todd Hannemann
HA newbie
PowerHome - UPB - ELK
| Posted: September 30 2008 at 14:23 | IP Logged
Received the unit today and realized that I'll either need to get some help on tweaking the plugin or reinstate my CID macro.
The change would be adding a * between the ata and the ath.
More later!
| Posted: September 30 2008 at 17:28 | IP Logged
I am still having a problem with the CID plugin not operating properly.. Can you help me add the ata and ath... to the macro?
On a side note dose anyone else think that the source code of the plug-in's should be released on the site along with a wiki tutorial so the users can tweak and release more of them... adding tons of functionality to PH2
HA newbie
| Posted: September 30 2008 at 17:38 | IP Logged
Sure.
If I had VB6, I would second that!
| Posted: September 30 2008 at 18:15 | IP Logged
can we use vb2008 express edition to recompile?? I was thinking of that....
HA newbie
