tbeckman Senior Member
| Posted: October 03 2008 at 19:21 | IP Logged
I am trying to create a button on the CC that will toggle a light off/on, while at the same time show the status of the light by changing it's background color. I can get the background of a button to change colors, but I can figure out how to get a single button to send an off signal when on and a on signal with off. Can this be done for a simple minded person?
Also, I can't see to figure out the graphic up and down files... I have pointed both these variables to a different graphic, but when I push the button, it doesn't change graphic (or even look like it is down versus up), but the light is controlled. Am I thinking about this correctly? Thank you.
