williammanda Groupie
| Posted: January 23 2009 at 20:08 | IP Logged
Please explain the trigger ID number field in the trigger settings. For some reason I'm thinking it needs to be unique but something tells me it might not be. If I have several triggers, shouldn't they all have a different trigger ID number?
Edited by williammanda - January 23 2009 at 20:10
| Posted: January 23 2009 at 20:29 | IP Logged
Trigger ID number is the Group number of the device firing the trigger. For example, if you are using KPL button 5 to fire the trigger, the ID number 5 (Group 5 for button 5) would be specified.
| Posted: January 23 2009 at 21:49 | IP Logged
If the trigger id number = the group number (found in insteon explorer\links\responders\group)and there is no number what should I use? See photo.
| Posted: January 23 2009 at 23:19 | IP Logged
What are you trying to trigger from? If it is the MBLIGHT turning ON, Trigger type would be Insteon Group IN, Trigger ID would be MBLIGHT, the Trigger ID number would be 1. Generally basic Insteon switches, ToggleLincs, SwitchLincs, ICON switchs, and so on, use Group 1. KPL group numbers are the same as the button number.
