krommetje Super User
| Posted: April 23 2009 at 16:39 | IP Logged
Anyone have an idea or a URL on info on how to make a Vista Gadget for PH?
Peter
| Posted: April 23 2009 at 16:54 | IP Logged
That would be interesting. You mean as in Control Center?
| Posted: April 24 2009 at 00:29 | IP Logged
Well, i am thinking about a small gadget which has a drop down menu and runs macros.... it is just html with some extra settings in css if i am correct....
Peter
| Posted: April 24 2009 at 08:54 | IP Logged
Yes it is mostly HTML. If someone has some spare time this information should be helpful building the gadget. I know there are those out there that are proficient in HTML coding.
| Posted: April 24 2009 at 11:18 | IP Logged
reading now.... mmm testgadget doesn't turn up in the list!
I think since all is done locally, the socketserver needs to be used...
| Posted: April 27 2009 at 15:54 | IP Logged
TONYNO where are you....
I think some WSH inside HTML should do the trick
like this (a working snippet that starts notepad.exe form a webpage)?
<HTML>
<HEAD>
<TITLE>test</TITLE>
<SCRIPT LANGUAGE="VBScript">
Sub Window_Onload
Set objShell = CreateObject("WScript.Shell")
Set objWshScriptExec = objShell.Exec("c:\windows\notepad.exe")
Msgbox "The application has started."
End Sub
</SCRIPT>
</HEAD>
maybe we can brainstorm any further on this?
Edited by krommetje - April 27 2009 at 16:48
| Posted: April 30 2009 at 06:03 | IP Logged
No answers yet...
I have gotten thus far:
I have created a gadget. It is basic html with VBScript and calls a batch-file which in turn calls phsscmd.exe with parameters. Disadvantage is that for every action, you have to create a seperate batchfile.
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="GENERATOR" content="Amnesty Generator 0.5b">
<style type="text/css">
@import "generator.css";
</style>
<script type='text/javascript' src='generator.js' charset="utf-8"></script>
</head>
<body onfocus='generator_setup();'>
<div id="gadget" onmouseover='generator_track();'>
<HTML>
<HEAD>
<TITLE>test</TITLE>
Sub Window_Onload
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\1.bat")
End Sub
</SCRIPT>
</HEAD>
</div>
</body>
</html>
the batchfile speaks for itself....
now for the enhancement of the HTML-file....
Peter
| Posted: April 30 2009 at 07:58 | IP Logged
I think Tony is on a hiatus. So what parameters are in the batch file? I’m sure they speak for themselves but I’m dense Peter.
| Posted: May 01 2009 at 02:42 | IP Logged
BeachBum wrote:
I think Tony is on a hiatus. So what parameters are in the batch file? I’m sure they speak for themselves but I’m dense Peter.  |
it is just a basic batch-file:
cd\
cd peter
cd phsscmd
phsscmd.exe ph_macro('huiskamerlampen aan')
I choose this method instead of the dirict one so I was sure that at least the PHSSCMD section works. I've have the tendancy to mix-up " with ' so.....
Update:
I've got the whole thing working in HTML/VBS
<HTML>
<HEAD><TITLE>krommetje test gadget</Title></HEAD>
<BODY BACKGROUND="m45.gif" TEXT=#FFFFFF>
<Form name=listing>
<select name=choice>
<option selected value=1><B>Lights on</B>
<option selected value=2><B>Lights Off</B>
<option selected value=3><B>Frontdoor down</B>
<option selected value=4><B>frontdoor up</B>
<option selected value=5><B>backdoor down</B>
<option selected value=6><B>backdoor up</B>
<option selected value=7><B>maikelight</B>
</select>
<P><input type=button value="run" onClick="options_onclick(listing.choice.value)">
<Script Language = VBScript>
sub options_onclick(f)
select case f
case 1
case 2
section2
case 3
section 3
case 4
section4
case 5
section 5
case 6
document.write "sectie6"
case 7
document.write "sectie7"
end select
end sub
</Script>
</CENTER>
</BODY>
</HTML>
together with phsscmd.exe and the batchfile it should be capable of running as a gadget! As you see, the html/vbs is actually just a VBS-menu which calls a subroutine in the case section which in turn calls the batch-file...
just edit the html/vbs to your needs (see section 1 in the VBS as a guidance), create the batch-files and you're in business.
Peter
Edited by krommetje - May 01 2009 at 02:49
| Posted: May 11 2009 at 10:03 | IP Logged
Congrats on the progress! I was out-of-commission for a bit, but I'm back now.
| Posted: May 11 2009 at 10:52 | IP Logged
Hey TonyNo
how do you like my gadget so far? any ideas on how to make it better?
when running everything in html in a browser, all works, but as soon as the gadget is installed....
here is what I have so far:
<html>
<head>
</style>
</head>
<HTML>
<HEAD>
<TITLE>test</TITLE>
<P>
<P>
<CENTER>
<Form name=listing>
<option selected value=8><B>maikelight</B>
<option selected value=9><B>maikelight</B>
</select>
select case f
case 1
case 2
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\2.bat")
case 3
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\3.bat")
case 4
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\4.bat")
case 5
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\5.bat")
case 6
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\6.bat")
case 7
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\7.bat")
case 8
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\8.bat")
case 9
Set objWshScriptExec = objShell.Exec("C:\Users\Peter\AppData\Local\Microsoft\Window s Sidebar\Gadgets\Peter's X10 gadget.gadget\9.bat")
end select
end sub
</Script>
</CENTER>
</BODY>
</HTML>
you can download the whole package here:
http://www.krommetje.nl/download/petergadget.rar
Edited by krommetje - May 11 2009 at 11:03
| Posted: May 12 2009 at 09:24 | IP Logged
So, it works fine in IE?
FYI, no Vista here.
| Posted: May 12 2009 at 13:30 | IP Logged
nope... ie says fault!
| Posted: May 20 2009 at 05:49 | IP Logged
An Update:
I've got the error (those fr**k**g """""again)
the HTML/vbscript works, but now the batchfiles aren't executed... reason is the administrator rights in Vista policy....
but he Gadget Runs!!!!
Get the skeleton: phgadget.rar (I will mail this to Dave for downloading)
You need: SteelRunAs.exe to be downloaded from www.steelsonic.com/steelrunas.htm
Create a batchfile for every action you want in the gadget, the batchfile calls phsscmd.exe with parameters for that action. use CMD as extension...
Run SteelRunAs.exe and select the batch file(s) needed for the gadget. SteelRunAs creates a CRC and compiles the CMD-file(s) to an EXE file(s),
Copy all files to a seperate directory, name the directory e.g. Powerhome.gadget
If the generator.html runs in IE, it will run as a gadget...
Copy the whole powerhome.gadget directory to the local gadget directory on your computer and your done!!!
Add the new gadget to the sidebar....
You need a working phsscmd.exe (put the location in the PATH)
Peter
Edited by krommetje - May 20 2009 at 10:09
| Posted: August 20 2009 at 11:39 | IP Logged
I went to work on a second gadget and wanted to do the following:
retreive an internal PSP page with 2 GV's, save it it:
ph_saveitcurl("http://192.168.1.251:9600/meteo.psp","C:\Prog ram Files\powerhome\web\gadget\gedget.html",1,30)
and show it in a vista gadget with an inlineframe.
my question:
it worked Once and now I am getting an error 4....!
I checked writing permissions....all is OK... why?
