Posted: December 17 2014 at 14:11 | IP Logged
Dave-
This is probably for you to answer unless someone else knows.
I am trying to write a (long) number (ie, temperature like 23.1 degrees) into the userdata2 "valnum3" column, which is allegedly a numeric column.
BUT I am getting an SQL error comment saying my temperature cannot be converted to a datetime value.
I thought this column (as well as the other "valnum" columns were supposed to be defined as numeric, not timestamp fields.
ALSO note the error comment says 'EMT-FREEZER...' and not 'TEMP-FREEZER' as it should.
Am I missing something, or is this a db error?
Posted: December 17 2014 at 18:56 | IP Logged
Ken,
Couple of errors. Valnum3 is indeed a numeric field of type integer (use the "select * from sys.syscolumns where tname = 'userdata2'" to see the actual layout of the table) so will not hold a decimal value. Valnum4 is a numeric of type double so you would have to use this field to store a decimal value.
Second problem is that variable substitution is not done in the SQL editor...only in the PH Formula editor. So {TEMP-FREEZER_C} means nothing to the SQL interpreter and the {T will instead be interpreted as some type of SQL escape character....probably convert the data to a timestamp, hence your error. The SQL editor is ONLY a SQL editor...no functions, variable substitution, etc.
Posted: December 18 2014 at 07:01 | IP Logged
Well now that sure makes sense !!
I kinda thought that since the Editor was embedded in PH that things would get interpreted, but that was just wishful thinking.
For future reference, would you recommend this site as a good reference source for PH SQL care and feeding?
http://infocenter.sybase.com/help/index.jsp?topic=/com.sybas e.infocenter.dc00801.1530/doc/html/san1281564727527.html
Posted: December 18 2014 at 09:20 | IP Logged
Ken,
I checked out the link and it would be mostly relevant. The SQL reference is for Sybase IQ which is definitely a different animal from the SQL Anywhere 11 database engine used in PowerHome.
I did some more searching and was able to find a SQL Anywhere 10 SQL reference on the Sybase site. This would be ALOT closer to what is currently in use in PowerHome.
http://infocenter.sybase.com/help/topic/com.sybase.dbrfen10/ pdf/dbrfen10.pdf?noframes=true
Posted: December 18 2014 at 09:35 | IP Logged
Downloaded the PDF and it looks extremely helpful.
Now I am DANGEROUS!
So, I need to ask again (you may have missed my other posting at the same time as this one), can I create my own Table, as the userData Tables are not quite appropriate for my schema?
I know I can create a table, but don't know what its impact might be on PH, thus need to know if there are any special considerations I need to be aware of. I am also assuming I can view (SELECT *) and use this new table.
Posted: December 18 2014 at 10:50 | IP Logged
Ken,
See other post for answer concerning create table.
