PowerHome Programming
Subject Topic: How to prevent multiple triggers Post ReplyPost New Topic
MrGibbage
Super User
Super User
Posted: April 17 2015 at 04:29 | IP Logged Quote MrGibbage
I thought I remembered seeing a cool trick using the boolean field to prevent a trigger from
firing multiple times within X seconds. I did some searching here, but no joy. Anyone remember
how to do it? I want a trigger to fire only if it hasn't fired within the last ten seconds.
Skip
Back to Top View MrGibbage's Profile Search for other posts by MrGibbage
smarty
Super User
Super User
Posted: April 17 2015 at 08:20 | IP Logged Quote smarty
and
ph_macroparm("TRIGGER-DISABLE",10,0,0,0,0) + 1
In the Boolean field of the trigger.
