PowerHome Programming
Subject Topic: User Message Box Post ReplyPost New Topic
smarty
Super User
Super User
Posted: June 15 2006 at 15:49 | IP Logged Quote smarty
Is there anyway to change the size of the user message box? Is there anyway to change the font size of the text message that is being displayed?
I am using the message box to display the contents of a caller ID txt file. The scrolling is nice, but I need bigger text, and a bigger text box.
dhoward
Admin Group
Admin Group
Posted: June 16 2006 at 15:10 | IP Logged Quote dhoward
Smarty,
Not currently. I would have to look into the best way of handling this.
In the meantime, you may want to look into something like the formula below:
ph_run('"C:\Program Files\Internet Explorer\IEXPLORE.EXE" http://127.0.0.1:8000/ph-cgi/directhtml?html="<html> <body> <h1>This is the message</h1> </body> </html>"')
This or something similar may get you by.
Edited by dhoward - June 16 2006 at 15:14
smarty
Super User
Super User
Posted: June 18 2006 at 14:32 | IP Logged Quote smarty
When I run this formula line, it opens IE. I guess I am supposed to use my local IP address rather than the one listed (right?). It comes up with a page cannot be displayed error message.
Additionally, to really make use of PH, I guess I will have to learn some HTML code to understand PSP pages. Where is the best place to start to understand HMTL code? Night class? Playing with an HTML/web page generator like MS FrontPage? Where do I start since I really only know BASIC type languages?
smarty
Super User
Super User
Posted: June 18 2006 at 14:35 | IP Logged Quote smarty
Ok...I am dumb AGAIN!
I removed the :8000 (port command), and it displayed the "This is the message".
onhiatus
Senior Member
Senior Member
Posted: June 18 2006 at 15:08 | IP Logged Quote onhiatus
Smarty, html is really not very difficult. I mostly use notepad ;-)
Having said that, Front Page makes it a lot easier to design your page - I tend to design my page with bogus values, then go back and directly in the source, sub in the psp substitutions to get those values from ph.
The psp stuff is really easy, you just enter PH formulas.
I'm quite proud of what I've got powerhome doing. Here's a live screenshot of the page I've designed for a touchscreen. When I get it a little farther on I'll post the page someplace so people can play with it...
Back to Top View onhiatus's Profile Search for other posts by onhiatus Visit onhiatus's Homepage
TonyNo
Moderator Group
Moderator Group
Posted: June 18 2006 at 17:13 | IP Logged Quote TonyNo
Looing good! Nice and clean.
onhiatus
Senior Member
Senior Member
Posted: June 18 2006 at 17:24 | IP Logged Quote onhiatus
Thanks. I was going for simple since the touch screens I'll be using aren't the highest res. (640x480). The page actually uses a lot of jscript. Clicking on pretty much anything brings up an overlay with more info - weather details, schedule info for the days that aren't shown - days that would stretch the screen are made invisible and their small icon versions are displayed instead(SA, SU, MO, & TU in the screenshot above), Bigger traffic map, etc. Best, I use scripting to load a separate data file into an iframe so that the page does not flicker when it reloads.
dhoward
Admin Group
Admin Group
Posted: June 19 2006 at 16:29 | IP Logged Quote dhoward
I wanted to check out your screenshot, but it doesnt seem to be coming through. I would love to see what you've done so far.
Also, if you do get to a point where you're a little farther and don't mind, posting the script code would be awesome. I always get a kick out of seeing what other users like Tony, Peter, and others have done (and I get a chance to sometimes learn something .
Also, having said that, there is a new function in the next beta called ph_openiewindow(). It allows the user to specify a title, URL, timeout, x, y, width, height, and flags and open a custom usermessage (or full URL, etc.) on the fly. Should take care of the configurable message needs.
dhoward
Admin Group
Admin Group
Posted: June 19 2006 at 16:31 | IP Logged Quote dhoward
Never mind...I refreshed and the screenshot came through. Looks great .
TonyNo
Moderator Group
Moderator Group
Posted: June 19 2006 at 18:48 | IP Logged Quote TonyNo
Will be ph_openiewindow be added to dcc?
dhoward
Admin Group
Admin Group
Posted: June 19 2006 at 22:43 | IP Logged Quote dhoward
Yep...thats the plan (I still remember from way back when . That and playsound and TTS.
